No matter what microsoft page i open the q key keeps coming up on it as if i had my finger pressed down all the time. I rang our local computer shop and he says that i need a new keyboard and if the keyboard is only accessable through the laptop it would be cheaper to buy a new one
Understand and use (or make sure they’re turned off) keyboard Accessibility Options. There are several types of help for those with typing difficulties, namely:
StickyKeys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneously.
FilterKeys: You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally.
Bounce Keys: If you bounce your fingers on keys inadvertently, Bounce Keys will ignore repeated keystrokes until some time has passed. You choose the time period.
Repeat Keys and Slow Keys: The computer will ignore brief keystrokes according to the time limits you set.
To access these Options and turn them off or on, go to your Control Panel– click Start >Settings >Control Panel >Accessibility Options.
By default it opens to the keyboard tab. If you are experiencing a sudden onset of bizarre typing behavior, your first step is to visit here and ensure that there are no checks in the three checkboxes, which indicates these Options are in use.
I mentioned that shortcuts ‘activate’ these features — such as Tab+Enter, and a couple of Alt+a letter– and so you may have turned them on unintentionally.
If you do have some difficulty with your typing, such as happens when a Mr. Arthur Itis comes to visit, or/and if you have tremors, here is where you can enable these aids and tweak their settings to get the most benefit from them. Click on the “Settings” button to see the choices. Below is the FilterKeys Settings dialogue.
In the case mentioned, my client had first held down the Shift key long enough to activate FilterKeys (because a finger “rests” there). The lady was an extremely fast typist, and this setting ignored her strokes as being too short. Since she has no use for this tool, I recommended that she uncheck the top checkbox and disable the activating shortcut.
This screenshot shows the settings for StickyKeys, and unless you have trouble holding down more than one key at the same time — such as Ctrl+Alt+Del to activate Task Manager — I suggest you uncheck the top checkbox here as well.
