Faberware FCP240 Coffee Maker Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a replacement pot for a micro-perk coffee maker.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 18, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1294
Points
8
Ronald Callahan
Level 2:
Scholar:
  • Expert 176 Answers
  • Posted on Jun 29, 2010
Ronald Callahan
Expert
Level 2:
Scholar:
Answers
176
Questions
0
Helped
40141
Points
219
Go t eBay and look for Farberware parts
Why doesn't percolator run long enough
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
How to use a Gemco Micro -Perk 4 cup percolator
Here is the paper with the info on how to use and care for the Micro-Perk coffe pot.. Hope this helps you as much as it helped me :)
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Perks ok coffee lukewarm
After perking the coffee the pot is to switch to a thermostat to keep the coffee warm...that thermostat is probably bad...
Not sure if it is replaceable on those pots...
Would call the Customer service number for the Regalware...
http://www.regalware.com/customer-service/contact-us
heatman101
* Contact
262-626-2121
1675 Reigle Drive
Kewaskum, WI 53040
(google map)
5helpful
3answers
Need directions for the Micro-Perk microwave coffee brewer
i recently bought a microwave coffe maker and it also has no instructions,,, help its from a company called colony...
Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
5helpful
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Top Faberware Coffee Makers & Espresso Machines Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
john h
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
