All of a sudden I have no address bar, no carousel, no back button, features especially the carousel that led me to put up with aol's problems. How do I get them back?
If you right click the task bar (the bar the time is on at the bottom of your screen) you will get a toolbar menu where you can select which toolbars appear
I had a similar problem when I found that feature. Look for a gray bar at the bottom of your screen. If it is there you should be able to slide everything over. Then on the right in the address bar at the top look for a percentage number. Clicking on that number snapped my screen back to the original size.
Google Chrome Beta version 10.0.648.127 has annoyed a lot of users. What annoyed the users is not the whole feature but the bookmarks bar which keeps on disappearing. It appears randomly and disappear suddenly. This gives a lot of people a headache. However, there is a way on how to make google chrome bookmark bar to stay. Here's the tweak.<br /><br />
<ul>
<li>Hit the <b>wrench</b> button</li>
<li>Select <b>Tools</b></li>
<li>Select <b>Always show bookmarks bar</b></li></ul>That's it! No more headaches. <br /><br />
You might have faced issue like not seeing address bar and tools menu in Mozilla Firefox sometimes. You might bit embarrassed by this. Here is the simple way to get your address bar and tools menu bar in Mozilla Firefox
Mozilla firefox will like this when the address bar and tool menu disappears
Now you need to press ALT Key on key board.Now you can see the tool bar and menu bar. To keep this settings, right click on VIEW option and Check options like Menu bar, Navigation Toolbar and Bookmarks Toolbar.
You are missing your navigation toolbar. Hopefully you still have the menu bar where it say's, "File Edit, View etc." Move your mouse up to the View tab and left click that tab. That menu should open. Slide down to toolbar and items like Menu Bar, Navigation Toolbar should have check marks beside them. You probably don't have a check mark next to Navigation Toolbar so, left click that location. Upon completion of last instructions the address bar, refresh and back and forward should all reappear.
Address bar dissapeared? Going to VIEW, TOOLBARS, place a check by ADRESS BAR then you should see in the top, right corner: Adress. right click it and un check LOCK THE TOOL BARS. Then you should see a thin line across the rest of the standard buttons, place the curser on it and move it up and down untill you see a two sided erow then drag the thin line untill you see the address bar.
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
The theme is probably bugged with 3.0.5. Try using a similar theme and see if you get the same issue. Or reinstall the theme as you may have corrupt files.
refresh, back button on aol doesn't work
