Toshiba Satellite A205-S4617 Notebook Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba satellite a205-S5847 cuts off while working
Toshiba satellite a205-S5847 while working whether it is plugged or unplugged.
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Aug 19, 2009
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7913530
Points
102259
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Toshiba satellite a205 will not turn on is it the power supply regulator on top rear panel?
Check AC power cord, use a different one, also plug into different outlet. If that doesn't work power switch is bad. Or something else is wrong.
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
How can I connect my Toshiba laptop to apple tv?
Try disabling the firewall temporarily. Also if you have an internet security antivirus then it has a firewall also you should disable.
Drivers toshiba satelite A205-S5847 WINDOWS 7 ULTIMATE
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
When I plug my headphones in they don't work
You can find two plug-in pins in the other end of your Headphone which is to connect the Laptop. You need to check whether it get connected properly in appropriate pin hole, if it doesn't work you need to unplug and try connecting in the alternate pin hole.
Hope this helps.
Recovery disk wont work because of preinst4.swm
you probably need a functioning Windows Operating system to copy the disk.
If you havent had it for too long, you could try sending it back to have the O/S and other original software reinstalled.
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Toshiba Satellite A205-S5804
Sometimes Electrical devices conflict with wireless signals,i.e. Cordless phones,Mobile phones are the worst,also the area you have placed your router can affect the performance of the signal. Also try unplugging the router for 30 seconds then plug it back in. This reboots the router and sets up a new stronger signal.
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
