SOURCE: which way do I turn temperature control to make it
You turn it clockwise but I ask you this. Was it cold enough before. If so you may want to take off the bottom panel and brush the dirt off the condenser coil it will extend the life of the unit.
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
SOURCE: i have a kenmore freezer
The higher number is colder and the lower is warmer....or 1 warm and 6 coldest...
heatman101
SOURCE: I have a Whirlpool Model EV 200N Upright Freezer
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
