Mdl #790.75503202. Fan constantly runs and displays "door locked" after clean cycle. Disconnected power source for days, same result.
In some Kenmore ranges, they wired a thermal fuse in series with the temperature sensor. And sometimes during a self-clean cycle, the fuse will open up. And this makes the EOC (Electronic Oven Control) think that the oven is extremely hot, so it locks the door and turns on the cooling fan. To fix the problem, you have to locate and replace the thermal fuse.
Note: In some other ranges, if the temperature sensor goes bad (opens up), you will get the same result. You can test the temp sensor with an ohmmeter. At room temperature, the resistance should be around 1100 ohms. If it's FAR from that, then you have a bad temp sensor.
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
SOURCE: My Kenmore Warm and Ready drawer self cleaning
Hit cancel or kill the power at the electrical/breaker box.
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
