SOURCE: dried water droplets on inside of lens
The camera lens will have to come completely apart, and all the pieces be cleaned. This is not something you can do yourself at home. Because there is water in the lens, there is the risk that the humidity will cause corrision of some of the pieces and electronics inside of the lens unit.
You an try leaving the camera in a dry warm place that is not more than about 100 deg F for a few days to see if the water will dry out. But, I am sure that there will be water stains inside on the lens surfaces.
Jerry G.
SOURCE: Bushnell Tour V2
This happened to me on the first round of use. I replaced the battery and it worked fine. I guess the battery that came with the unit was not very good
SOURCE: Bushnell Tour V2..no display
If the unit gets hot (like in the trunk of a car), the LCD display will go out. Keep it in the house and it should get better when it cools.
SOURCE: Bushnell Rangefinder Tour v2 E31 appears in viewfinder
If it is 2 years or less from the date of purchase.....send a copy of the POP (proof of purchase) or call them......! It should be under warranty. This is the real deal!!!
rate if you can!!
MTG
SOURCE: Bushnell Tour V2 2nd Distance Digit Missing
It seems that Bushnell in the UK refuse to offer a repair service to any of their units outside of their 24 month warranty.
