20 Most Recent
Bushnell Optics 2x24 262024W Prowler Waterproof Night Vision Questions & Answers
Waterboss water softner. E1
THis has happened to me a couple of times and i have fixed it by doing the following:
1. slide the electronic display unit off its base
2. spray a bit of WD 40 on the 2 gears right next to each other (they are gold and black on my unit)
3. spray a bit of WD40 on the large grey wheel on the other side of the 2 gears. The 2 gears are supposed to turn the grey wheel, which in turns pushes a little black plunger in with one of its three little prongs. Use a screw driver to make sure that the plunger is moving freely - push it in and out a few times and put a bit of WD40 on it.
The whole error code is about that large grey wheel not moving - it is the "magnetic disc" that the owner's manual refers to.
Finally, reposition the elwectronic display unit - make sure it is tightly secured in its original position, or it will not work.
Unplug the power to the display unit and then re-plug it back in. The unit should go through its cycle on its own then...assuming you don't have any damaged parts. Hope this helps!!!!
Eyepiece assembly bushnell telescope
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
