SOURCE: My Linkasink is leaking at the bottom edges.
You need to seal from the outside edge and I would use a clear silicone made for use in wet conditions. It wouldn't hurt to put a bead around the bottom edge as well.
SOURCE: ingrained glass on top shelf
Hello. Begin by running the dishwasher after adding two cups of vinegar. Use the hottest and longest cycle u have. This will clean your machine. Then change over to cascade liquid and see if it imakes a difference. Finally, always run the hot water in the sink until it is real hot before you turn on your dishwasher.
SOURCE: Adhesive for granite tiles on kitchen counter?
Mortar, go to a tile supply store and ask for the best tile mortar for granite.
Glue is fast and easy but pails in performance to that of mortar.
SOURCE: How to remove a sink, sealed with silicone
Try using a long piece of dental floss, like a saw, all the way around until you cut through the silicone.
SOURCE: windshield leak began on passenger
Windshield leaks are very difficult to stop. Not even pros can get it right all the time.
There is a silicone windshield sealant (Pep Boys) which has a consistency allowing it to "run" down into the holes / cracks -- sometimes this works sometimes it doesn't.
Yes, windshield trim will need to be removed...
And, yes, the light fixture should come off from top of vehicle, and "standard" silicone caulk can be used around that fixture to stop leaks.
Charlie
