First start off by making sure the cable is untangled. Next when placing it in the pool only allow enough cable to reach the other side of the pool. Place the setting on 1 and wrap the excessive cable up using a zip ties. This should solve your issue. Thanks and Good Luck!
Remove weights, Thoroughly clean cleaner, backwash filter system to get optimum suction. Check filter system for optimal suction..., ie. leaks, excess debris, clogged baskets, strainers, etc..
SOURCE: trackball not moving right
This is right, the problem is in the trackball. If you can get hold of alcohol like the one used years ago to clean the heads of tape decks etc, you may be able to put some in the trackball and rotate the ball around in all directions with the hope that it may clean it.
SOURCE: HEADLIGHT WONT FLIP UP HELP!!!!
headlight relays? located on the fender wall 8-12inches behind headlight. way to check is to switch them. also a third one(mine has a broken mount)under air filer can. hope this helps
SOURCE: Robo Kleen moves but does not clean
If you can, connect it to the back wash of your pool fiter pump. Just for a few secondds that usually works well.
SOURCE: flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
