Stainless steel strap broken at the rubber clasp think you must by the whole strap?model no. on reverse 3319 aq-160
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Here is the link for Casio accessories:
http://www.casio.com/products/accessories/filter/?CAT_Title=Timepiece&SEC_ID=E796490D-5A99-480F-A3AD-1B8E01AB4067&PRO_ID=C9BF1225-D682-445E-AC0F-F88BD7338A72
If no luck, then click on the @Contact Us@ tab at the bottom of same page.
Rate me please.
Had same problem with the non-metal strap breaking on CASIO AQ-160. It's a fine watch but the design puts a lot of stress on the cheap strap and also on the tiny holes on the watch body where the strap attaches. I broke my watch by trying to squeeze the pins with my new strap replacement. So here's my solution: Go to Amazon.com (or elsewhere) and buy a whole new watch for under $30 U.S.D. By the way, the crystal scratches easily and I suppose that's what we get for a cool, but inexpensive watch. Good luck!
