Pioneer DEH-P690UB CD Player Logo
Posted on Aug 13, 2009
No audio from mini input jack on Pioneer SupertunerIIID 50w x4
I connected a mini cable to the one jack on the left of the backside but I only get a faint sound when I turn the volume all the way up.  However, if I turn it to tuner, the sound blasts from the speakers at that volume.  I tried a couple of different mini cables and they all had the same result.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Oct 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
10031
Points
26
The mini jack was not designed to work in the manner in which you are trying to use it. The stereo output is always going to be at a higher output rate than the amplifier output. if you want to use an MP3 player with your stereo you will have to purchase a head unit with a built-in MP3 input or deal with the lower rate of volume.
How do I connect a set of Pioneer 6ohm, 50w speakers to a DP42SM?
If the Pioneer speakers are of the active type (built in amplifier), you can connect them to the left an right analog audio outputs of your TV. If the Pioneers are passive speakers, you need to connect them to an amplifier/receiver first and then use an interlink cable to connect amp/receiver to your TV.
Why is there no sound coming out of my goodmans 50w sound bar?
No. Red and white are left and right stereo sound. Yellow is for video. Do you have power to the sound bar? Are those red and white cables connected to audio OUTPUT on the TV? If they are connected to the audio INPUT to the TV, it won't work. You may need to connect the cable to a 'phones' jack on the TV. Can you connect the sound bar to another source (like an iPod or CD player)? That will test the sound bar itself.
2answers
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
How do i connect my wii to my new samsung ue46d6530?
Input &
Output
HDMI 1.4 (3D Auto Setting/Return Channel):4
USB:3
Component In (Y/Pb/Pr):1
Composite In (AV):1(Common Use for Component Y)
Digital Audio Out (Optical):1
PC In (D-sub):1
CI Slot:1
SCART:1
RF In (Terrestrial / Cable input):1
RF In (Satellite input):1
Headphone:1
PC Audio In (Mini Jack):1
DVI Audio In (Mini Jack):1 (Common Use for PC Audio in)
Audio Out (Mini Jack):-
Ethernet (LAN):1
Initially I thought the problem was going to be no composite input on this television. However according to the specs there is one composite (yellow, white, red) input and that is where you connect the wii. Is the problem that you've already connected something to the one input and you're looking for another spot to connect the wii? There is a wii component cable http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
1helpful
4answers
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I have a lg plasma and im trying to connect it to my pc hooked up the vga in the comp and on the backside of my tv, have the audio and hooked it up to the audio, but when i change input i can see the pc on...
It sounds like you are using the wrong audio input jack, by chance are you using the audio cable with RED and WHITE RCA to mini stereo plug ?
If you look at the VGA port on the the TV, you will see a small mini phone jack (PC audio) close by, that will be for the sound input when TV is in PC mode.
Please verify for me.
1helpful
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
1helpful
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
2answers
Avic-d2 and itouch
you can play the video on your player, and see to it if there is an input jack at the back of your unit, such as rca jack,mini jack or special connector , and try to set the menu botton if there is an input selector.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
