Hi, your washing machine need to be leveled, use a spirit level, to level your washer, used washer legs for adjustments, after leveling of washer, place both hands on machine, and try to rock side to side, front to back,there should be no play (movements) on washer, make sure machine is firmly position, good luck.
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
On something like this you will need to remove the washer wrap to
inspect the suspension springs & base assembly. Please see the link
provided for accessing the inside of the washer. Be sure the shipping
pins have been removed. The tub should float freely.
I had this problem as well.
I called dealer and Maytag.
They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad.
It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer.
Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
This solution applys to many Maytag washing machines. Perhaps not all.
Maytags have three damper pads in the bottom of the machine that must be lubricated from time to time. If they are not, they can be ripped off. They are glued to the bottom of the machine, the drum rests on top of them. When they become dry or lost, the machine shakes violently and no amount
of leveling or load balancing will fix it. Replace and/or lubricate the pads and magically it works again.
This is not a difficult repair for those that have modest mechanical skills and a few basic tools.
replacement pads and lube come in an inexpensive kit.n
I will create a web page with instructions if there is interest.
