Microwave Ovens Logo
Posted on Aug 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the hotpoint microwave model # RVM1535DM1WW
Does this microwave have a built in fuse? does the hotpoint microwave model # RVM1535DM1WW have a fuse in it? Microwave has stopped getting power and will not work.
Anonymous
Level 3:
  • Master 636 Answers
  • Posted on Aug 13, 2009
Anonymous
Master
Level 3:
Answers
636
Questions
Helped
264705
Points
2016
Yes most of them do, take the outer casing off, should be located either were the power supply is or the control module is,
We have Hotpoint Model # RVM1535DM2WW microwave that all operations work except it stopped heating. Manufacture date is Jan 2010.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
3helpful
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Power just stopped working. Is there a fuse built into the oven?
Yes there is a fuse which is built within the oven. Open the back cover and locate the fuse which is located in the power supply board. Replace it with same value.
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
1helpful
Microwave just died
The Microwave should be on a different circuit than the fridge. If the fridge kicks on at the same time you have the microwave on high you can damage them with low voltage causing high amperage and blowing the fuse, try replacing the microwave fuse and try to run it off a circuit that the fridge is not on, New hoses have a dedicated plug for just the microwave oven, I own a 1.4 cubic foot oven and it had to have it's own plug due to the breaker size and wire size, it pulled to much power to be on that circuit. So change the fuse if that does not work and post here and will see what else to check, and please rate if this helps.
Won't work
unplug your microwave; remove the top under the top you will see a small white cylinder
(a ceramic fuse) it looks like a glass fuse only made of white glass replace this they are sold at radio Shack
Changing the fuse in microwave hotpoint mosel JES636WKo1
This model seems to have a fuse in a cylindrical white nylon fuse holder, probably located near the right rear.
It will also have a thermostat on the magnetron which may be out.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
