swan34 When you turn the unit on it starts to "warm up" and then after about 15 seconds it shuts down, Starts flashing an F then it Flashes a 2. The Diamond shape on the trouble board lights up red and flashes as well. Thank Youswan34
Thank You
You can't post conmments that contain an email address.
F2 code means a problem with toner cartridge error. Sometimes F2 is caused by loss or broken harness in the scanning section, in this case, it sometimes displays an E7 code. When f2 flashes on display just press the Start key you will receive a subcode. If the subcode is F2-02 this is a toner supply problem. If the F2-04 toner chip is damaged, replace the chip. If the F2-40 developer is damaged, change the developer
Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
This code you may have to clean out the developing unit and start with a fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one.
Replace the toner cartridge.
Change the developer.
If you find your parts, then replace the parts and error still remains, after automatically reset the error code. If the error is still showing even after the above solutions, then you have no choice other than calling Sharp service technician.
well this is normally toner bottle gear is tight or micro electronic card is defected which you can see on toner cartridge but if them ok check socket where this micro card pin goes if connections r fine and u replace developer did calibration but still same prolem then u need to check the board if u have tested main board where toner connector goes jus swap hope fully will be ok let me know
It sounds like you have a bad toner cartridge. There is a chip on the rear end of the toner that is sometimes defective. It doesnt happen often, but it happens. blog.equipmybiz.com
hello, F2 04 Improper cartridge (destination error, life cycle error). Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one. the toner cartridge seems to be the problem.
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
swan34
Thank You
