Televison & Video Logo
The chu Posted on Jun 21, 2019
Large equipment stuck on glass surface
Tv stuck on glass stand
1 Related Answer
happinessfre
Utah
  • 107 Answers
  • Posted on Oct 24, 2016
SOURCE: stuck on stand by
Hey there, the seed for http://normative.io/ was planted when two friends, the mathematics student Kristian Ronn, and the urban planner Robin Undall-Behrend, decided that they wanted to dedicate their career on doing the most good. http://normative.io/
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
tip
HYUNDAI HLCD-32ZT4 DISASSEMBLING AND POWER SUPPLY CIRCUIT
DISASSEMBLING
Lay the LCD-TV on a flat, soft and clean surface
Remove the stand.
Remove the screws remarked on red to remove the stand.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
Have a dell 3115cn when copying from tray a line appears in the center how to remove line
lift document feeder cover, you will see the large glass surface, to the left of it there is a strip of glass about 2 cm wide. This is where the scanning from document feeder occurs. Clean glass with alcohol or glass cleaner
Apr 16, 2013 • Dell 3115CN
2answers
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
Yep. That's what the video shows as well if anyone else needs help. I'm glad you were able to figure that out and resolved it. Simple fix.
Horizontal lines on photocopies made but no lines appear when document document is printed.
Hi there, As it sounds its a dirty scanning glass. Open the top of the scanner so that you can see the scanning glass.. If your standing in front of it you will see on the left hand side a strip of thinner glass.. Take a damp cloth (better cloth with spirits/surgical alcohol) and clean the both the small and the large scanning glass. These lines normally cause if the glass is dirty. Especially if your using the document Feeder. As a lot of time wet ink or typex or correction fluid gets stuck on glass which will cause these lines.
Hope it helps
Regards,
28helpful
2answers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
I just purchased a ktm 450 exc ....... I have just been on a 300km ride over 2 days. (I had oil done before I left even though I only had 135km on it) Looking at the sight glass re the engine oil it...
with the bike standing on it's wheels and held upright. Be sure to give the oil time to run through the crankcase when you stand it up. Next time you change oil, don't go by the bubble. Read your manual and measure out the correct amount to add.
2helpful
2answers
How do you remove the glass from the rear side window regulator
Remove the door panel
  1. Remove the side impact bolster.
  1. Detach the door speaker (if equipped).
  1. Disconnect the speaker electrical connector and remove the door speaker (if equipped).
  1. Detach the door latch release handle.
  1. ani_caut.gif CAUTION: Do not touch the adhesive surface as re-bonding will be impaired.
    Detach the watershield.
    • Using a suitable plastic knife (disposable cutlery), cut through the Butyl strip to enable the watershield to be peeled back.
  1. Remove the door glass top run retainer.
Vehicles with manual windows
  1. Install the window regulator handle.
Vehicles with power windows
  1. Connect the door glass operating switch electrical connector.
All Vehicles
  1. Align the regulator clamp with the access hole (power window shown).
  1. NOTE: Position the regulator operating cable to one side when drilling the retaining pin, in order to prevent damage.
    Detach the door glass from the regulator clamp.
    1. Using a suitable electric hand drill and a drill bit 8 mm, remove the retaining pin.
    1. Push out the retaining sleeve.
    1. Remove the door glass from the regulator clamp.
    • Discard the retaining sleeve.
  1. Support the glass, lower the glass and regulator to the lowest position.
  1. Position the lower part of the door glass top run outside the door.
  1. NOTE: To aid removal of the door glass, stand on the inner side of the door. Make sure the glass is removed from the inside of the door.
    Remove the window glass.
Installation
All vehicles
  1. ani_caut.gif CAUTION: Make sure vise jaw protectors are used.
    NOTE: Make sure that the retaining sleeve is central in the door glass.
    Attach a new retaining sleeve and retaining pin to the door glass.
    1. Position the retaining sleeve in the door glass.
    1. Using a suitable vise, press the retaining pin into the retaining sleeve.
  1. Install the window glass in the door.
  1. Attach the door glass to the regulator clamp.
    • Push the door glass firmly down to engage the retaining pin and retaining sleeve into the regulator clamp.
  1. Position the lower part of the door glass top run on the inside of the door.
  1. Close the window.
  1. Install the door glass top run retainer.
  1. Attach the watershield.
  1. Attach the door latch release handle.
  1. Connect the door speaker electrical connector (if equipped).
  1. Install the door speaker (if equipped).
  1. Install the side impact bolster.
  1. Remove the window regulator handle.
  1. Disconnect the door glass operating switch electrical connector.
All vehicles
  1. Install the door trim panel
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
