SOURCE: euro pro 9136 wont work
Could be the drive belt from the motor to the machine is too loose, get a new one. Will the machine turn by hand, if not, then there may be something inside jamming it
SOURCE: euro-pro sewing machine repair
If you call the company, they will probably send you whatever you need. 1-800-361-4639
SOURCE: Sewing Machine Motors Runs But Needle Does Not Move
Probably the belt tension needs adjusting, it is slipping like a car fanbelt and needs the same relative "give" when correctly tightened.
Remove the side cover where the handwheel is and loosen the motor fixing to adjust and increase the tension on the belt ....needs some slack, if you can move the belt 10mm with light pressure then it will be fine NOT TOO TIGHT or you will overload the motor. NOTE: If the side panel is not easily removed, ie 2 piece casing split in the middle, take it to a service centre or risk breaking the casing trying to get in....if it is more than a few years since last service, let someone do it all and get a sweet machine back, with no risk for not a whole lot of time or money
SOURCE: friends broke needle on my euro pro multi stitch sewing machine.
I have a Euro-Pro Multi-stitch and I use regular needles, nothing special. Singer needles is what I usually buy but only because thats what I can get where I live.
SOURCE: Euro-Pro 998A Sewing Machine needles
the size & type needle depend on the fabric you use to sew,
try these sites for parts
allbrands.com
searspartsdirect.com
denversewingenginemedic.com
euro-pro.com
sew4less.com
drdanessmh.com
