1994 Acura Integra Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 Camry Often Won't Start When Hot Outside Unless Jumped
This happened last July but hasn't happened again since until this week. The car is a 2001 Camry, V6, in good shape. Fluids are all fine. Last battery check was a year ago, and it showed no problems. Electrical functions seem to work, but the car acts like it doesn't have enough power to start. When you turn the key, you can hear the loud clicking from the electrical connection trying to catch. Any ideas??
Problem summary --
Thursday: Car starts fine at about 10:30am, drives without problem in city for 15-20 minutes, sits on / idling while waiting to pick someone up, drives another 5 minutes. Return to car 1 hour later, and it won't start. Find someone to jump it, and it starts immediately and without issue as soon as I hook up jumper cables to the other vehicle. Drives fine the rest of the day.
Friday: Car starts fine, and has no issues for 15 minute noon-time trip. Starts slightly slower than normal but still almost immediately. Make several short trips and return home without a problem. Go out for dinner / movie at 8pm, and no problems after dinner or after movie.
Saturday: Still slow starting but no issues on 30 minute trip at noon. Car sits in sun for 2 hours, but shows no problem during 3 stops after on way home. Notice that power windows are slow to roll up when arriving home.
Sunday: Nine in the morning, car exhibits same problems as Thursday when it won't start.
  • zippytwl Aug 09, 2009
    Yes, I personally wonder if the battery has a bad cell that wasn't caught last time I had it checked. At first I thought maybe it was a fuel relay, but I don't know how that would be solved immediately by jumping the car.
    As for draining or bad alternator, I don't think either is the problem. I would think draining would be a constant issue, not intermittent. Likewise, if it were the alternator, I would also expect to have some sort of problems when driving. However, once started, the car has no problems.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1801
Points
7
First off, your alternator is fine since once you jump start it it keeps running. I would check your ground connections and make sure they arent corroded. There should be at least two good size ground wires in your car. One from the battery to the chassis and the other from the chassis to the engine block. Once you rule that out, try a new battery though I have a feeling it's a loose or a corroded ground wire.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 315 Answers
  • Posted on Aug 09, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
315
Questions
0
Helped
108962
Points
930
Well is the battery draining over the time its sitting?
could be a bad battery or alternator, and/or you might have something on the car constantly draining power from the battery.
best to have it looked at by a mechanic.
2001 mustang has new battery, won't start unless it's jumped, then dies after trying to drive a few yards
You have a defective alternator most likely, have it tested by any Autozone it is free.
1helpful
Ford taurus 2001 car start but once the car is cut off it won't start up again until it cools off the car is not running hot.
After you kill it, when you try to start it back up, does the starter turn the motor? Or is it froze up (will not turn over)?
Electric fans shut off in hot weather
Be very careful as this can cause the head gasket to blow off and messing up your engine.A very simple solution to this is to disconnect the wires that plug into the thernostat,follow the cooling system and you will see it that connects to the fan.Disconnect it and the fan will run once ignition is on.
2helpful
2answers
2002 toyota engine, oil sludgecaused my car to stopped and now needs overhaul
Complain to Toyota, they are fixing some of these car for free. Here is the explanation and the list of problem vehicles.
Oil sludge or black sludge is a solid or gel in motor oil caused by the oil gelling or solidifying, usually at temperatures lower than 100 degrees Celsius. Sludge can be a major contributor to Internal combustion engine problems, and can require the engine to be replaced, if the damage is severe. Sludge is usually caused by the presence of water in the oil, and can accumulate with use. Ways to minimize sludge production and accumulation includes performing frequent oil changes, using synthetic oil, and following the manufacturer's engine maintenance routine.
The following engines were reported by the Center for Auto Safety and/or their manufacturers to have a problem with sludge accumulation:
  • 1996-2001 Toyota 3.0 L 1MZ V6
  • 1996-2001 Toyota 5SFE I4
  • 0helpful
    Blower motor works intermittenly & I smell burning wires
    you need to replace motor itself im sure on this you can find a used one on car-part.com i should have one [email protected]
    2answers
    Faulty beetle
    common for cranksensor to play up on a bettle,you dont say if it is petrol or diesel though
    MY TEMP GAUGE IS REGISTERING HOT WHEN I AM RUNNING MY A/C AND WHEN I TURN OFF THE A/C IT WILL START TO GO DOWN TO THE HALF WAY POINT OR LESS. THIS IS A 2001 MAZDA 626 LX. I HAVE NOT HAD THIS PROBLEM UNTIL...
    had the same problem before. there are certain reasons solutions, just look where it best fits you.
    1. check your radiator, maybe lid is loose.
    2. check your radiator, maybe it's clogged and needs to be overhauled.
    3. check and replace thermostat switch. maybe worn out (most probable cause for this is exactly what happened to me)
    switch is found in the engine, it looks like a spark plug.
    hope it helps.
    Top Acura Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    ROBERT GARCIA
    ROBERT GARCIA
    Are you an Acura Expert? Answer questions, earn points and help others
