Hinge on the back left side is not closing properly
SOURCE: Broken latch on hinged back
Try calling Canon's parts department at 1-732-521-7230 and see if they still have the part in stock. The part number is CF1-3129-000 and should cost less that $2.00 I think.
CameraRepairs
SOURCE: Gateway left hinge broke
Not a very hard thing to do. Should buy in pairs. Here is one place that has them for sale.
http://www.mundocorp.com/shopexd.asp?id=6655
SOURCE: Both the freezer and fridge
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
SOURCE: one of the hinges on the door seal has come off
Open the little metal screw on the larger hinge that is between the top and bottom hinges. This will allow to pull the seal all the way out. There is wiring behind that middle hinge so watch not to damage it. Then , you can realign the 3 hinges in their place and replace the screw in its position. It takes a little bit of patience to realign the 3 hinges but it's very doable.
