Has sound, no response to flashlight test, I can see by the power led that it is power cycling about every minute.
Https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=2ahUKEwji8unanvLiAhUNvFkKHScgAhkQwqsBMAp6BAgJEAQ&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Df324xmqpsMs&usg=AOvVaw3HWv-VEEbI-cYRoIqW5IvV
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=12&cad=rja&uact=8&ved=2ahUKEwji8unanvLiAhUNvFkKHScgAhkQwqsBMAt6BAgJEAc&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DvTshhd0lOVM&usg=AOvVaw3ROg8dOTQLccq0kFy4iTuB
SOURCE: No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
SOURCE: Vizio Plasma 42HDTV - Power, No Video
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. If by chance the TV is still under warranty, go that route.
2. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Sounds like you had a high voltage power surge just before going out
Are u using a high grade reference center or surge stage 2 or 3?
SOURCE: bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
SOURCE: Will power up but black screen with no sound
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
I have made $100 per hour in one day.That was my perfect day in my life and my employer was quite happy with me.I'm manhandle relate online business likelihood I perceived concerning and I've made such not all that terrible cash. last month her pay check was $12712 just working on the laptop for a few hours..check further details by open the link and click on HOME TECH OR MEDIA.
===>> www.broguru.com <<===
