SOURCE: Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
SOURCE: bread dough
Hi. There are several possibilities. First, you should always proof your yeast. Take a 1/3 cup of WARM water, add a half tsp.of sugar and yeast, wait 10 minutes. If your yeast becomes frothy its active and can be used. If not, get some fresh yeast. Second, use a flour that has a high protein content (10-12%) if you're not using pans to make your bread. High protein develops more gluten than low protein flour. Gluten development will give your dough body, and prevent your dough from flattening. Third, after mixing. knead the dough by hand for 8-10 min., cover and let rise until doubled, punch dough down and divide. Knead the portions by hand for 8-10 mins. Shape loaves and place on baking sheet or use pans,let it rise untill doubled,then bake as usual. Been there...Done that. Let me know how you make out. Ricardok45.
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
SOURCE: bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
SOURCE: is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
