20 Most Recent Tilia FoodSaver V2240 Questions & Answers
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
Tilia FoodSaver... | Answered on Feb 18, 2019
http://www.foodsaver.com/ For technical support.
You should be able to just push it back in. You have to take it out to hook to the vacuum port don't you? Here is another link for manuals on this.
http://kitchen.manualsonline.com/ex/product/headline/m/foodsaver/d/food_sealer/p/FoodSaver%2BUltra
Tilia FoodSaver... | Answered on Jan 25, 2018
Foodsaver has a toll free number that you might call to see if they can provide the part. 877-777-8042 is what is listed.
Tilia FoodSaver... | Answered on Dec 08, 2017
You need new replacement gasket, to get one, visit amazon FoodSaver Vacuum Sealer Upper Gasket Assembly T910 00075. I hope this was helpful. cheers foodsaver-v2440-vacuum-air-out-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Tilia FoodSaver... | Answered on Jan 03, 2017
Thanks, Lee Eismann. This was very helpful. I was about to purchase marine silicone as you suggested (washing and drying the sealing gaskets did not solve the problem for this time, which it did several months ago when this problem occurred) when I realized I had can a spray silicone that I keep like WD-40 to lubricate moving parts when they squeak. I sprayed this on both sides of both gaskets as well as the sealing roller and it immediately solved the problem. This tip should be in the owner's manual as it's clearly a very common problem.
Tilia FoodSaver... | Answered on Nov 01, 2015
Easy.. It fits around the 'mouth' of the trough either in the lid or the matching surface in the body.. It should be one piece and unbroken... If it's broken, then check eBay for a replacement
Tilia FoodSaver... | Answered on Feb 02, 2015
What is the issue?
Tilia FoodSaver... | Answered on Jun 11, 2014
Hi, it might be a problem with the sealing pump or something electric. If you are within the US or in Canada please contact us with your serial#: 1-888-956-6866 X: 234 OR X: 235. Eurodib
Tilia FoodSaver... | Answered on Feb 11, 2014
Tilia FoodSaver V2240 Logo
168 questions posted
Top Tilia Kitchen Appliances - Others Experts
elementsandt
Level 1 Expert
Sheldon Dedek
Vitally Alcher
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Tilia Kitchen Appliances - Others
Most Popular Question
foodsaver v2440 vacuum air out
  • Kitchen Appliances - Others
