Hi the switch is pressed in so will need a repair see link
https://www.ifixit.com/Guide/HTC+10+Disassembly/74008
SOURCE: Can this camera be RESET? Camera Stuck in Clock set mode.
If you are familiar with camera repair then apart camera and check navigation switch board is intact with main board of camera.
That is only reason of switches no operation in this camera.
SOURCE: Returns to standby 5 seconds after selecting mode
check for shorted speaker wire strands at one end or the other. That can cause amp to auto-disconnect to prevent damage
SOURCE: Zen pad 10 wont turn on. Its says select boot mode. Wont let me do anything.
I would try a factory reset and see if that straightens things out.
Turn off the computer, then hit the power button to
turn it
back on and immediately start hitting the F8 key repeatedly until you
see SAFE
MODE. Take the Safe Mode With Networking option (this will give you
internet connectivity) and let it boot up. Safe Mode will look
different to you, the screen will be darker and the icons bigger, this
is
normal. When it boots up, open your internet browser and download and
install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type:
"Download cnet Malwarebytes" (without the quotes). Download and
install malwarebytes from the sites download.cnet/malwarebytes. When the
site opens up click on the Green Download button on the left. Do not
click the Red Download button, that's junk. When it finishes installing the Gui
Interface will open up with an offer to Accept a Trial Version or
Decline. CLICK DECLINE you want the totally free version. Run a
QUICK SCAN. As it scans, if it finds infections the number will be in
red. When it finishes scanning, click SHOW RESULTS. A notepad text
document will open up showing you the results. You can close the text
document and go back to the Gui Interface where you will click REMOVE SELECTED
RESULTS. The objects will already be selected for you. When it
finishes removing the objects click ok and it will sometimes reboot your
machine.
If the above steps does not fix the problem:
Try another mouse and see if it scrolls.
