Cell Phones Logo
A
Anonymous Posted on May 31, 2019
When I plugged my Nokia E7 it flashes but won't charge
Anime Series
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 22 Answers
  • Posted on May 31, 2019
Anime Series
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
22
Questions
0
Helped
2300
Points
53
Try to go back to the shop where u buy it or try to go to a shop that repairing phones
3 Related Answers
Priyesh Vadher
  • 547 Answers
  • Posted on Jun 23, 2012
SOURCE: my nokia E7 phone's charging pin is loose connection.has the mother board damaged?
it is difficult to know, because you need to open device and check or show some oficial repairer
Anonymous
  • 6 Answers
  • Posted on Sep 21, 2012
SOURCE: how to change nokia e7 charging point
Remove the battery, get some methelated spirits some paper towel and a toothbrush. (Do Not Use TURPS!) Gently dip the toothbrush into some metho then scrub out the usb port with it facing down, so that minimal metho gets into phone. It will evaporate fairly quickly so don't be worried. Use the paper towel to soak up excess metho. Then use a magnifying glass or jewelers lube and check if all the pins are entact, do likewise for the charger end also. Should work ok after that, if not buy a new charger. Good Luck! :)
Anonymous
  • 33 Answers
  • Posted on Dec 13, 2012
SOURCE: My Nokia E7 phone's charging but not conected on PC,what can i do.
BEFORE PLUGGING UP TO COMPUTER
menu -> settings -> wireless and networks -> USB utilites -> connect storage to PC (click this button) -> it'll give you a message "Connect USB cable to use mass storage" ... connect the usb cable -> the android man will pop up w/ a msg saying "Phone connected to computer via USB. Tap the button below to copy files between computer and Android's USB storage" theres a button below that says "connect USB storage" (click on this).
your all set
I have forgotten my password for nokia e7 how can i hard reset
Follow the steps to hard reset nokia e7:
Before doing the master reset and format Nokia E7, ensure that you have backed up important data
1. The Nokia E7 battery should be charged fully
2. Turn Off Nokia E7
3. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
4. The Nokia E7 will reset
OR
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
GuruAid.com
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Reset password
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
your all set
9helpful
2answers
My nokia E7 was not charging properly because of loose connection in the phone. I gave it to Nokia care for repair,but he says that the mother board has to be replaced.I want to know if he is right...
I don't think, due to charging problem the solution is to change the motherboard.For charging problem there are several tricks to repair.The cost for changing the motherboard will as similar as buying a new phone with the same model.So, my comment is to visit another mobile repairing shop.If there is a loose in the charging interface it can solve by changing the changing socket or you can see another solution from this Nokia E7 Charging Problem.Good luck
My nokia E7 phone's charging pin is loose connection.has the mother board damaged?
1helpful
Nokia e7 00 not charging
Hello I am on my third E7 within 12 months, due to the device not charging. I think I have found a fix, well it is currently charging as I type this so maybe it will work for you as well. The 2nd E7 died when I let the battery completely run down, plugged it in over night, in the morning powered up and it turned straight off again. Plugged it in and I got the blinking/flashing charging light for about a minute then it would turn off. I phoned up Vodafone and they offered to send me a new one without questions, so I assume this is a well known fault...the only problem I had was that I had not backed it up in a couple of weeks and needed to get the data off. When the new one arrived I thought I could swap the batteries over (once fully charged) and then sync over bluetooth...there are a couple of very good tutorials on YouTube for replacing the battery. Once I had taken the device apart I thought i would try leaving the battery out of the unit for 10 minutes or so and then try plugging the charger back in...please be very careful if doing this with the phone in pieces....and all of a sudden the nokia logo appeared on the screen and I have a solid charging light!! So I assume all is charging as it should I might even be able to do the sync over the cable... Got to be worth a shot as sending it off to Nokia Care takes ages and I run my business through this phone, so not having it for any lenght of time is not an option, also they do a hard reset as standard so data will be lost guaranteed! Good luck and I hope it works for you! Sam PS: Just powered it up (while charging) and it has turned on so this has definitely worked for me...will post this on other forums..
2helpful
My nokia e7 won't turn back on
I had the same problem with my E7, but after removing and replacing the battery it was fine. If you've already tried holding the power button down for 10 seconds then you'll need to follow the guide below..
7helpful
My nokia e7 won,t turn on. Worked fine when i put it on charge the night before and the next morning the screen was blank and i didn't managed to get any response out of my phone
I had the same problem with my E7, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
I have nokia e7 I want to know is there any way to stop phone getting charged when we connect phone to laptop via its data cable
No but you shouldn't worry about it. It doesn't damage the battery and it'll stop charging when full.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
