20 Most Recent Nokia E7 (16 GB) Smartphone Questions & Answers
2answers
Bottom part touch screen not working nokia e7
change your firemware
11/18/2019 4:17:31 AM • Nokia E7 (16 GB)... • Answered on Nov 18, 2019
Nokia E7-00 will not charge
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
7/6/2017 4:36:06 PM • Nokia E7 (16 GB)... • Answered on Jul 06, 2017
Need a manual on nokia e17 on internet
manual on nokia e17 Caroline, Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://disneybackuper.weebly.com/blog/free-download-nokia-e17-user-manual-programs
8/10/2016 12:40:31 AM • Nokia E7 (16 GB)... • Answered on Aug 10, 2016
3answers
Forget security code nokia e7 how to unlock
The default security code for Nokia is 12345 or 00000 you can use it. If you want to unlock your Nokia E7 you can use the codes ie the unlock codes. Get the unlock codes using the site Onlinegsmunlock.comand unlock it easily.
5/16/2016 5:06:38 PM • Nokia E7 (16 GB)... • Answered on May 16, 2016
How to disassemble
10/18/2015 2:52:30 PM • Nokia E7 (16 GB)... • Answered on Oct 18, 2015
Disassemble nokia e7
10/18/2015 2:32:31 PM • Nokia E7 (16 GB)... • Answered on Oct 18, 2015
2answers
Touch screen not responding
Try calibrating the screen via your settings menu in the touch input selection, at the bottom you'll see calibrate touch screen.
5/11/2015 11:21:52 AM • Nokia E7 (16 GB)... • Answered on May 11, 2015
My e7 automatically swithing off
Try a hard reset by entering *#7370# into your phone. The default security code is 12345. Don't forget to make a back up of your data as well so that you can easily move everything back onto the device after the reset. You can make a back up with Nokia Suite If this doesn't fix it, reinstall the current software with Nokia Suite. This should solve any errors in the phone. Belle will be rolling out soon as well, so if reinstalling Anna doesn't work you can try Belle instead, when it becomes available. If, after trying all the above, the phone keeps switching itself off, I would definitely recommend bringing it to a local care centre where they can check it out and fix the issue for you. Your phone has a 24 month warranty period so this won't cost you anything. You can find a local care centre by visiting your local Nokia web page and clicking on the Support tab. To find out the expiry date of your warranty, you can call your local care line. The only thing you need is your IMEI, which you can find by entering *#06# into your phone. The phone number for your local care line can also be found under the Support tab on your local Nokia web page.
1/19/2015 5:58:45 PM • Nokia E7 (16 GB)... • Answered on Jan 19, 2015
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock? Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above. What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code? If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7. How to Restore Clean Setting at Nokia E7 Reinstall the Operating System? Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted. Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster? It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7. How to Fix Forgot Nokia E7 Pin or Password ? If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
11/26/2014 3:24:08 AM • Nokia E7 (16 GB)... • Answered on Nov 26, 2014
Need more solutions on how to reset my security code of a Nokia E7
How to Perform Soft Reset of Nokia E7 with Secret Security Code: Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
11/26/2014 3:20:28 AM • Nokia E7 (16 GB)... • Answered on Nov 26, 2014
2answers
I want a unlock code for my nokia e7 my imei number is 354864044624543
8/21/2014 9:58:31 AM • Nokia E7 (16 GB)... • Answered on Aug 21, 2014
Nokia e7 connector
Do you want a Nokia E7 connector? If so, you can get it from any Nokia priority dealer.
7/12/2014 12:06:07 PM • Nokia E7 (16 GB)... • Answered on Jul 12, 2014
HOW CAN I RESTORE MY NOKIA E7-00 WITHOUT CODE
You can enter *#7370# and then enter the lock code (12345 if unchanged). Remember that this will permanently wipe your phone of any apps, data or settings. Your SIM card will remain untouched, though.
6/30/2014 8:26:53 AM • Nokia E7 (16 GB)... • Answered on Jun 30, 2014
My earphone jack broke and i want to listen to music through headphones
This problem is hardware type and I think it can only be solved by local Nokia support shop or authorised technitian.
4/30/2014 6:19:21 PM • Nokia E7 (16 GB)... • Answered on Apr 30, 2014
0answers
How to unlock that nokia e7 of f-secure ?
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Master reset code:1122Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
3/11/2014 10:19:04 AM • Nokia E7 (16 GB)... • Answered on Mar 11, 2014
Nokia E7 (16 GB) Smartphone Logo
211 questions posted
Popular Products
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
E Nokia
  • E Nokia
Most Popular Question
earphone jack broke want listen music
  • Cell Phones
