SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
SOURCE: I have a Troy Bilt Bronco, Kohler 18 engine
its the coil it has the same one as a 12.5 has
Testimonial: "I haven't checked that yet... Gonna try to figure it out. I appreciate the advice though! ;)"
SOURCE: I NEED A DIAGRAM OF A BRIGGS AND STRATTON TROY
Go to link below for a parts break down for your tiller. Starts on page 23
http://dl.owneriq.net/c/c23c1d7c-74ff-4347-b31e-a0ee0462b35e.pdf
SOURCE: I just replaced the drive
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
