Step 1
Press the "Power" button located at the top of your Sanyo remote control to turn your television on.
Step 2
Press the "Reset" button located next to the power button.
Step 3
Press the "Reset" key a second time to reset your Sanyo television and restore its factory settings.
Should you require further assistance. please reply to this directly
Thank you.
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
SOURCE: Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
SOURCE: My Sanyo DP32649 Will not turn on. The green light
Sounds like the power supply is bad.Do you know anything about working on circuit boards ? I bet some of the capacitors need replacing.This is a quick and very cheap fix if you know how to do it.
On the back of the tv is a panel held by two screws.Remove those and you have instant access to the power supply.Look and see if any of the capacitors are bulging or leaking.
SOURCE: No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email [email protected]
