Computers & Internet Logo
Sheila Renee Fritsvold Posted on May 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use battery charger Belkin F8M744 - Belkin Computers & Internet
Larry Ng
Level 3:
Top Expert:
  • Belkin Master 14,606 Answers
  • Posted on May 26, 2019
Larry Ng
Belkin Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280552
Points
66651
I clicked google
then "Bilkin support" no quotes.
found them in 1 second flat
then search box there, your model
and go this, (spoon feed day)
https://www.belkin.com/us/search?text=f8m744
2answers
Battery does not want to charge
Could be variable reasons -> If you're using generic brand chargers or charger adapter (these have various voltage settings on them and numerous tips for insertion into charging location on unit). This is often an issue with regular cell phones as well. If you don't use the same brand charger (or at the least, one of the reputable 3rd party manufacturers, ex: Belkin)...Most importantly, make sure the charger output matches input of the phone. If you're unsure, check you owners manual for specifications. Do the same for your charger specification. If it's quicker to use the internet. Search the net for your phone model. This also includes the info you need for the charger...Depending on the age of the battery and/or the tablet/e-reader. Again, there could be many variables
TuneBase FM Transmitter and Charger for Apple iPod: Belkin for my ipod the green light comes on but it...
I need user instruction to get started can't find anywhere on the internet. Please advise. Angie Thank you
My Belkin wall charger will not charge my BlackBerry Bold 9700 using the mini USB cable. It had no problem charging my old Curve.
Make sure it is correct for the one you are charging, use your user manual for instructions and details.
download a user manual, if you don't have one.
I am running without the battery in place and my USB ports and my wireless adapter, Belkin, do not function.
Many laptops do not work correctly without the battery. The charger gives a basic voltage to the system and the peripherals need the battery to be in place for their supply.
Will my Belkin ITE Power supply Model No.AC08 ET19941 LPS be safe/effective for charging my iPod Classic? This is an AC wall charger with USB connector presumably ok for the iPOD or other USB powered...
Yes as long as the wattage voltage etc... align between the device and the max output of the adapter you should be just fine in this particular case. I have the same adapter and I can not even remember what it initially came with but it has been so handy that I will keep it as long as it lasts. ;)
Palm i705 won't turn on
are you certain that the belkin universal charger, is compatable with the palm ?
if any single cable, is wired differently. this could have damaged the palm.
try a hard-reset using your palms user manual.
this varies between pdas, usually comprising of either a reset hole, at the bottom of the palm, or underneath the battery on certain models.
i,d suggest obtaining the correct charger/usb cable.
as you may cause damage to the unit. most new devices have a battery fitted, but does not necessarily mean it,s charged.
Hope this helps, please rate the solution.
Mike @ compurepair.
3answers
LAPTOPS KEYBORD
Uninstall the Belkin software and see if it helps. If not, then you will have to do a soft reinstall of the OS over the curent install with your Packard Bell Windows Cd, or a fresh install. (Make sure you make a back if you are doing a fresh install.
If you have made a restore point earlier, you can try to restore the system to a point before you installed the Belkin router. This way you do not need to do a fresh Windows install. But you will lose any data you stored since the time of that restore point.
11helpful
2answers
Belkin ups not working properly.... green and RED light on ...indicates bad battery. But unit not more than 1 yr old, no battery time at all when plug pulled...not enen i min on (desk to an d monitor
Your batteries are weak...(causes
1:-not powering the UPS for a longtime
2:- long use(3 to 4 years) )...you will have to replace them
PLEASE RATE ME.................
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
