SOURCE: embroidery downloads baby lock ellure plus
If not a USB model, you have to get the disgustingly expensive Babylock palette box ($500) and software with the blank card to transfer the designs from cd or files. Beware of making the embroidery too small, it can make the stitch density too great and then the machine cannot sew the design. There is software called Density Works to deal with this problem.
SOURCE: Baby Lock Ellure
I HAVE HAD THIS HAPPEN SEVERAL TIMES AND WHEN I WOULD CHECK THREAD IT WOULD BE OK, MOST OF THE TIME HOWEVER, IF I COMPLETELY UNTHREAD IT AND RETHREAD IT THE PROBLEM IS SOLVED. I HATE IT WHEN THEY DO THIS MUST BE A PROBLEM WITH ALL OF THEM
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
SOURCE: I bought a Baby Lock.Ellure embroider/sewing
I have a Babylock Ellure Plus. To space between words there is a _ on the front with the letters. This will insert a space.
