Hello Larry, indicate brand, model and type of equipment, which you mention, to try to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Larry, indica marca, modelo y tipo de equipo, del cual haces menci?n, para tratar de poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: Pairing Jawbone 2 with BlackBerry 8700
Just put your jawbone in pairing mode, usually by press and holding the on button for about 10 seconds. you should see the light flash blue and red alternately.The go to options on your BB and bluetooth then press the ball and add device you will have an option for allow another to find me, click it and when your jawbone pairs put in the default code which should be 0000 or 1234
you device will pair and your set
