20 Most Recent
Sony BD Remote Control for Playstation 3 Questions & Answers
Instructions for sony bd remote control
You can also plug in your Keyboard/mouse (any usb type keyboard and/or mouse will work with a PlayStation 3). That will allow you to navigate the PS3 XMB Menu, as follows:1) Prepare the BD Controller.2) Go to: (Settings) > (Accessory Settings)...3) Select [Register BD Remote Control].4) Follow the on-screen instructions to register the BD remote control. When the registration, or pairing, is complete, your system will assign a controller number to the remote.Hints
- You can register only one BD remote control at a time. If you register another BD remote control, you will overwrite information on the currently registered device.
- After you reach the maximum of seven active wireless controllers, you cannot register or use a BD remote control.
- Registering the BD remote control with another PS3 system will clear the device registration from the first PS3 system.
- For details on the BD remote control, refer to the instructions supplied with the remote.
Ps3 controller charging failed
ok, either your charger for the ps3 is broken...or,it cant read(know)the cord is there. you may have dust or something clogged up. i know cause it happend to my ps2...i blew into the slot where the controller goes ( although u need to blow into the charger where u plug it in. if it doesent work... then u may need to either try a different usb plug or controller and see how it goes...OR take the controller and charger to a friends house if they have a ps3 and see if it works on theirs..if it vworks on theirs...then the thing where u plug the charger in at on the ps3 is probably broken or clogged up with dust...if it doesent work on theirs than your usb plugs are brokn...
Althogh no other devices are
If there are no other devices attached, then probably the PS3 is having an error which is making it bring out the false message or there might not be enough voltage in the console.
Turn of the PS3, remove the power cord, then wait for 45mins to 1hr. Turn on the console and see if the false message is still going to come up. If the message still comes up, the it means you have to reset the console. Follow the below steps to reset your PS3.
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If the none of the above solves the problem, please let me know so that I may direct you further.
I wish you good luck.
Regards.
Nre Sony BD/Playstation Remote Control
yeah to pair your rmote you have to register it in the
Settings then go to
Accessory Settings then go to
Register BD remote control not Manage blue tooth devices like PS tells you to.
then do the whole start enter scan bit
My childs PS3 control is not working at all. Any
DEAR FRIEND,
- KINDLY UNSCREW THE PAD
- THEN CHECK IF THERE IS POWER IN THE BATTERY
- IF THERE IS NO POWER IN THE BATTERY
- THAT MEANS YOU WILL HAVE TO BOOST THE BATTERY WITH A UNIVERSAL CHARGER
- AFTER BOOSTING THE BATTERY, KINDLY FIX IT BACK TO THE RIGHT POSITION
- ASSEMBLE THE PAD BACK AND TEST IT.
