Televison & Video Logo
Treacia Rasogo Posted on May 21, 2019
In chapter 4 why is tina unhappy - Televison & Video
2002 jeep liberty motor-2.4 chain driven component below crankshaft need to find if position matters and how to time
no photos. so help will limited .
all cam timing matters.
"not sure what does", the cam, crank, sprocket or pin?
The 2.4L inline 4 engine, is a throw back old Dodge Neons
DOHC engine ,a twin cam head.
2002 is first year, Liberty in USA>
is this the 2.4L turbo engine, EDZ engine.??
KJ jeep it is.
be nice to say what job your working? HOw'd you get here?
if you buy the service manual from jeep
chapter 9s, covers this 2.4 total engine, in one chapter.
but this engine cams are Belt drive. NOT CHAIN.
first post that it really is, this engine? or the VIN, or photos.
so you must be confused on that is there.
the other engine, the 3.7L is a V6 engine vastly different than the 4 banger.
it has chains.
covered in chapter 9- page 71 +
this v6 has a counterbalancer too.
i recommend reading the FSM book on this engine , after counting cylinder, 4 or 6? and reading chapters 9 or 9s.
see KJ 2002 here
RTM read the manual
seen here
http://colorado4wheel.com/manuals/Jeep/KJ/
How do i recalibrate the st4000 tiller for the starboard side
Hi Tina!
The ST 4000 is factory default to the starboard side. If you require a port side mount, see chapter 7 of the manual to which I have provided a link below. (3.16 MB) About halfway down the page.
The text reads as follows:
OPERATING SENSE REVERSAL
Press +1 and -1 keys together for five seconds.
The display will then show port or starboard and the phase of the autopilot will automatically change.
The control head will automatically revert back to its normal operation within 5 seconds.
Note: This should normally only be required if the actuator is port hand mounted.
Hope this helps.
(Sorry about the orientation of the manual, it's pretty cheesy coming from Raymarine.)
-Steve
Raymarine Retired Autopilot Manuals
Dec 05, 2014 • Boating
How can chapter titles be inserted into an existing document in Microsoft Word 2010?
Insert The Chapter Number And Title In A Header Or Footer
First divided your document into sections in order to insert chapter numbers and titles into headers and footers.
1. If you haven't done so already, insert a section break where you want to start a new section that contains a different chapter.
a. Click where you want to insert a section break.
b. On the Insert menu, click Break.
c. Under Section break types, click the option that describes where you want the new section to begin.
Note: If you have already inserted a page break to cause the chapter to start on a new page, delete the page break and replace it with a section break that starts on a new page.
2. Apply a built-in heading style to the chapter number and chapter title by clicking a heading style in the Style box on the Formatting toolbar.
Or to have Microsoft Word automatically number headings, use the Bullets and Numbering dialog box to format chapter headings.
a. On the Format menu, click Bullets and Numbering, and then click the Outline Numbered tab.
b. Click a chapter-numbering style (one that includes the text "Heading 1" or "Heading 2," and so on), and then click OK.
c. Type the text you want for the numbered heading, and then press ENTER.
d. To add the next numbered heading, go to the next chapter heading, click the arrow next to the Style box on the Formatting toolbar, and then select the heading style you specified in step 2.
1. In the first chapter, on the View menu, click Header and Footer.
2. If necessary, move the insertion point to the header or footer you want to change.
3. Insert the chapter number or title.
a. On the Insert menu, point to Reference, and then click Cross-reference.
b. In the Reference type box, click Heading.
c. In the For which heading box, click the heading that contains the chapter number and title.
d. In the Insert reference to box, select what you want to insert in the header or footer. For example,
• Click Heading number to insert the chapter number.
• Click Heading text to insert the chapter heading.
e. Click Insert, and then click Close.
4. Click Show Next Button image to move to the header or footer of the next chapter.
5. If the header or footer in this chapter matches the one you just created, click Link to Previous Button image on the Header and Footer toolbar to break the connection between the header or footer in the current chapter and the previous chapter.
6. If there's already text in the header or footer that you don't want, delete the text before inserting the chapter number and title.
7. Repeat step 5 to insert the chapter number or title of the current chapter.
8. For each chapter in the document, repeat steps 5 through 9.
Fan wont shut off in my 2001 nissian altima
Hi Tina,could be your blower motor resistor,it's located next to the blower,2 screws hold it on,remove electrical connector first,take to Autozone and get a new one,if it doesn't fix,they will take back and refund your money Tina.here's a link to the resistor Tina. Duralast Heater Blower Motor Resistor JA1219 at AutoZone com Here's a link showing you the resistor Tina. Repair Guides Blower Motor Removal Installation AutoZone com
Require a Unlock Code for region free
DVP 3618 - how to unlock region codes?
1. Power ON the DVD player with no disc inside
2. Go to the SETUP icon and press OK; next, go to
Preferences and press OK
3. With preferences highlighted,
3a. Press NEXT CHAPTER (button above AUDIO, it looks like
this: >'),
3b. Press PREVIOUS CHAPTER (button above SUBTITLE, it looks
like this: '<)
3c. NEXT CHAPTER >'
3d. PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
It works for DVP 3618 model.
1helpful
Philips dvp 3618 unlock region code
this: >'),
like this: '<)
3c. NEXT CHAPTER >'
How can i unlock all characters in dbz shin budokai another road?
Hello bambamverall
Go throughout story mode (Another Road), to unlock the following characters:
Vegeta (Majin) - Get ending A (can be obtained y not letting enemies destroy any cities in the last chapter).
Picolo (fuse with Kami) - Beat him at the alternate path of chapter 3.
Bardock - Beat him as Goku in chapter 5.
Super Buu with Gotenks absorbed - Finish the 2nd level of chapter 7.
Super Buu with Gohan absorbed - Finish the 3rd level of chapter 7.
Future Gohan - Finish chapter 5.
Dabura - Beat him in the 2nd level in chapter 2.
Cooler (final form) - Complete the 2nd mission in chapter 4.
Hope this helps, good luck!
ajblaj
46helpful
7answers
Bratz 4 Real - can't find Dexter in Chapter 9
dexter is in room 104 in the back iambuj
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
2answers
Wont boot just has series of beeps
Table 2. System Beep Codes
Beep Code Possible Cause Corrective Action
1 Memory refresh failure Reseat the DIMMs.
2 Parity cannot be reset Reseat the DIMMs.
3 Memory failure within the first 64 KB of memory Reseat the DIMMs.
4 Timer not operational See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
5 Processor failure See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
6 8442 keyboard controller error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
7 Processor exception error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
8 Video display memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
9 Optional ROM checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
10 CMOS memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
11 BIOS checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
