SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
SOURCE: white stripe on right as if black toner needs
We have the same problem.
Can you tell me where do I find the image path?
Thank you.
SOURCE: i need the radio wiring diagram for a 1992 cadillac eldorado
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
SOURCE: I just bought a Panasonic CQ-C1301U deck, and want
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
SOURCE: IAT sensor has 5 wires,
IAT is tan for signal, black for ground. Other wires are probably for the MAF.
