20 Most Recent
Clarion DRB2475 Questions & Answers
Clarion drx6275gv clock
I have tried all of the above solutions, but none of them worked! Does anyone else have another solution? Cheers.
We have installed a Clarion
I will make this simple for you. The yellow wire needs to go to a power source that is constant. Check the wire with a meter or a test light to verify it is constant regardless of what position the key is in. If you have a weak battery that makes your car hard to start this will cause the radio to lose power while the engine is trying to crank while starting. So if you have verified the yellow wire has a constant power source and the red is switched, This isn't rocket science...if it works the problem is solved. If it loses memory again its your radio with the problem period. Unless you have an intermitant constant power on the yellow wire
Need to know wire color for memory function on
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
I need a wiring diagram for a clarion drb2475 car
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
