SOURCE: Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
SOURCE: Light and flame work, but
Chances are you have a bad thermal in there. It is almost always on top over the coils. They usually go if the fan motor is soon going to quit or the air intake is dusty. Check the motor before replacing it, It should still work without heat on. Only change the thermal with the same temp rating !
SOURCE: I have a Amish looking
There are a couple of reasons the heating unit part of the fireplace stop heating. A dust and lint build up in the heating coils can cause them to burn out. The heater overload circuitry has shut the heater down or has failed or the unit needs to reset. so lets go to the easiest thing for you to do, yourself.
RESETTING THE HEATER
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace and wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON. Turn ON each individual function of the fireplace, one at a time. If the unit was able to reset itself, each function should work normally. If it doesn't, then one of the issues I listed above is the problem.
If your fireplace is less than one year old, it should still be under warranty. So contact the manufacturer (you can find the contact info in your Owners Manual) about repair or replacement.
One personal aside: None of the electric fireplace/heaters on the market today, have a long trouble free life span. Usually, it's 9 months to a year, when consumers start having problems. I sold these type of appliances for a couple of years, as an adjunct to our gas fireplace and heater business. When they started to become a problem for our customers, we quickly realized, that no matter who the manufacturer is/was, they are not what they are touted to be and we discontinued selling them. It's been 4 years since we discontinued selling them and apparently, nothing has changed in their manufacture. As, I answer more than my share of questions about them, here on FixYa. As one person told me, "I wish I had bought a vent-free gas fireplace instead. It would have cost me more, but would have been more reliable and would still heat, even if the power was out."
I hope this helps you trouble shoot and solve the problem.
Happy Easter!
