20 Most Recent Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote Questions & Answers
how to change in bulb in23EF010GAA
Leisure... | Answered on Feb 14, 2019
verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
Leisure... | Answered on Oct 09, 2018
It would seem to me that the Thermal fuse has "Blown" this is an internal protection device that operate from heat... they often fail spontaneously, when this happens oftem all else works but no heat.
You will have to take it to a reputable repair shop/man and get a firm "Quote" for repair.
Leisure... | Answered on Apr 20, 2018
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
Leisure... | Answered on Oct 24, 2017
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
Leisure... | Answered on Oct 19, 2017
Follow the pilot line from the gas valve this should show you where the pilot is .
Leisure... | Answered on Oct 15, 2017
Certainly ask a local electrician to take a look. Some electricians have a call-out charge and some don't so it is worth looking in your local directory and making a few calls. It would seriously take the good fortune from the fault being just a simple one if a hefty call-out charge was added.
Your friends and neighbours might be able to recommend someone.
Your post indicates the fire isn't very old. You presumably didn't buy it direct from the now-bankrupt company, but like most people you probably bought it from a retailer? The fact there is a guarantee the company can no longer honour is rather meaningless when your contract wasn't with the manufacturer but with the retailer.
When a person buys something a contract is made. In return for some money the retailer agrees to supply you with a fire that must be of merchantable quality. If it has worked for only a month it clearly wasn't of merchantable quality and the retailer should take responsibility for fixing it or replacing it.
Leisure... | Answered on Apr 05, 2017
If you have the old motor in your hands, go to www.grainger.com and they can cross ref. with the name plate data on it, and replace it for you.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Leisure... | Answered on Dec 19, 2015
If your On-Off is not working ? Go to GRAINGER and get Light Rocker Switch SPST,3 connections 2VLN1 or the Light Rocker Switch SPST, connections 1A824
both will do the job.
Leisure... | Answered on Nov 22, 2015
Maybe its the fireplace's ignition spark box at the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Leisure... | Answered on Mar 07, 2015
I took the fireplace's direct connect ignition spark box out of the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Hi clean pilot light check out thermocouple might need new one
Heating & Cooling Logo
358 questions posted
Popular Products
Top Leisure Heating & Cooling Experts
Paul Carew
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Leisure Heating & Cooling
Most Popular Question
need off swich
  • Heating & Cooling
