SOURCE: samsung clx 3175 toner chip overide/reset?
we use chip and fuse for samsung cartage reset when it give us cartage empty message. before geetting thish we gets tonner is low .if recently we filled samsung dust/powder/tonner in cartage we no need reseter. in my practics while i need to put fuse (reseter) i put iton cartage after resetin suddenly i putout it from cartage and use old fuse. in this way we can use or not green chips? actuly it is difficult.
SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
SOURCE: Samsung CLX-2160, keep getting faded
Many people will tell you it is an engineering problem that Samsung won't own up to (it isn't and that's why they won't own up to it). Others will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
SOURCE: Samsung CLX 3175FW printer toner cartridge
you need to get into technical mode, simply press menu > # > 1 > 9 > 3 > 4 and then press ok tech should be shown on the lcd screen, now go to the menu and data setup, look for memory clear or clear all memory, it should ask you for a destination country, if you choose your country at this prompt and press ok it should accept the toner
