SOURCE: Brake lights quit working.
if all fuses and bulbs are ok get to the brake switch and see ifits stiff or stuck, if it just has two wires on it you could join themtogether to see if the brake lights come on though obviuosly dont leave them joined.Good luck davelee
SOURCE: My 2002 Ford Ranger Edge brake lights do not work
Brake light switch It is on the brake pedal
SOURCE: front driver turn signal quit. changed bulb,
Check for head light (daytime)relay to be bad,this might have to do with the turn signals also,if the turn signals on this car,also have running lights in them,If this relay is not bad,replace the body control module.
SOURCE: tv remote quit working
The remote put out IR (INFRARED) signal that human eyes cannot see, you need to use your digital camera to see it, just point the remote at the camera's lens, you should see flashing light on your camera screen when any remote buttons is pushed.
You may have problem with the IR receiver in your TV, but find out first if the remote is putting out the signals
Parts:
http://www.shopjimmy.com/vizio-3642-0022-0189-ir-sensor.htm
worst case will be the main logic board.
http://www.shopjimmy.com/catalogsearch/result/?q=VX32L
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
SOURCE: the headlight on my bashan
Check the fuse, the electrical wiring and the connection terminals going to your headlight .
