Toys Logo
Ariel Guidry Posted on May 12, 2019
I plug my razor charger to my electric scooter and the charger blinks from green to red what does this mean
dadjr94
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 12, 2019
dadjr94
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
3691
Points
26
Usually means bad batteries or possibly a short.
5 Related Answers
Anonymous
  • Posted on Jul 19, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
clsnyder
  • 6 Answers
  • Posted on Apr 11, 2010
SOURCE: When I plug in the charger is shows green, but the
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Anonymous
  • 38 Answers
  • Posted on Aug 18, 2010
SOURCE: have an e100 razor electric scooter. it has not
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Anonymous
  • Posted on Sep 09, 2010
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Anonymous
  • 11 Answers
  • Posted on Jul 05, 2011
SOURCE: I own a Razor E100
If you mean it flicks straight over from charging to charged then this is classic signs the E100 battery is dead & needs replacing.
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Have an e100 razor electric scooter. it has not been used since I bought for a couple of years. I got a new e100 charger and tried to charge but I noticed that the charger's does not activate either red...
Most equipment running on rechargeable batteries have one thing in common: if you let the battery sit there for long periods of time without recharging, the charger is not made to bring the battery back up to spec. The battery pack, if it is still good, needs a "kick" or "boost" from some other strong supply to get it started.
The other solution would be to replace the battery pack all together. If you have a friend with a similar scooter, you can try your new charger on his scooter to see if it works. Hope this helps!
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
2answers
How long does it take to charge Razor E100 Electric Scooter - Red
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
1helpful
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
5helpful
2answers
On the charger it will go red green red green forever and i halve to charge it a week to go ten minuits
hi my son has not used the scooter for a while so i went to charge it and the green light comes on the charger straight away and the scooter is not working can you tell me what the problem is?
2helpful
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
