SOURCE: reprograming my universal remote
Hi
For Sanyo TV you can use the code "0154" Also you can obtain the User's Manual with code list from the link below
http://www.expressfix.net/manuals/remotes/URC-3021
SOURCE: lost directions for universal remote control
sent to me by nextech....
Save Code list for future reference. Refer to the setup procedure below and look up the 4 digit code for your brand of TV, VCR, etc., from the list below.
1519001B, 1519002B, 1519003B, 1519006, 1519007 CL
Refer to the Owner’s Manual for your remote for more information.
Direct Code Entry
1.
Press and hold the
SETUP button until the
red indicator stays on,
then release the SETUP
button.
2.
Press and release
the desired Mode button
(TV, VCR, etc.). The red
indicator blinks, then stays
lit.
3. Enter the 4 digit code from
the code tables. Note: after
a valid code entry, the red
indicator turns off. For
an invalid code, the red
indicator flashes.
4. With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of
the other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for
3 seconds.
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the
button.
3. Press and release the
desired Mode button
indicator blinks once, then
stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Most users will want to
store VCR codes under the
VCR button, Cable codes
under CBL, etc. If you want
to store a VCR code under
CBL, etc., first follow the
procedure for Direct Code
Entry and press CBL in step
2 of Direct Code Entry, then
enter ANY VCR code in
step 3 of Direct Code Entry.
Then follow the steps above
for Code Search.
Direct Code Entry
1.
Press and hold the
button.
2.
Press and release
lit.
indicator flashes.
brand.
3 seconds.
Code Search
to the right.
be controlled.
button.
desired Mode button
stays on.
for Code Search.
answer found at [email protected]
SOURCE: How to reprogram Harmony 520 to a replacement DVD/VCR?
You need the Harmony software on your computer that is available at www.logitech.com. You will then have to connect your remote to the computer to change your configuration using said software. You may need to start from scratch if you don't know the username and password for your Harmony account. The software will step you through setting up your remote it's fairly simple.
SOURCE: universal remote control rcr4383
open up the battery compartment and take out he batteries look for the model number example rcr4383 find it on this webpage
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca
click the number model that's yours and download the manual in a pdf.
:D
SOURCE: RCA universal remote
Try it without a code. Turn your tv off. Press tv then press the on.off button and tv button at the same time. When it lights up, press play every five seconds until the tv powers off. Next press the reverse button every few seconds (sometimes takes a while), until it powers back on. When it powers back on hit the stop button to save the code.
