I have a TruBolt electronic lever with keypad. The keypad will lock the door, but it will not unlock the door
Perhaps you need to change / add user codes?
(don't forget to change default pass-code too)
https://youtu.be/UAZ4Bwbz8eU
https://youtu.be/71t7ybLQzME
https://youtu.be/58D5vR-tBfA
SOURCE: 2002 VW Jetta WAGON GAS TANK DOOR LOCKED
look for an emergency pull cable in the boot (trunk) it should have one
SOURCE: The driver side door will
2003 nissan altima driver will open from outside but not from the inside.
SOURCE: My 05 Equinox drivers electronic door lock doesn't
YOUR REMOTE BATTERY NEEDS REPLACING.TAKE IT TO DEALERSHIP.THEY WILL REPLACE REMOTE ENTRY BATTERIES AND REPROGRAM THE DOOR LOCKS.
SOURCE: 1996 Explorer anti-theft system won't disable
Try re-setting the computer...Disconnect the negative terminal of the battery and leave off for 5-10 minutes. This will allow the computer to reset. The charger may have interupted the signal or something.
SOURCE: electronic door locks not working
It will be a bad microswitch in the mechanical lock driver's door and because of the microswitches do not get the impulse when other doors to unlock! Unfortunately, this microswitch is part of the lock and can be purchased separately! Only whole lock! ( Nr. 9. is it )
Testimonial: "Excellent advice - thanks!"
The keypad on our front door will allow the deadbolt to be turned but won't lock the door or unlock it for us. Possibly the same goes for your lockset. Did you install it or did someone else? Reason I ask is the instruction manual should have been kept when the hardware was installed.
