20 Most Recent
Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Questions & Answers
Kwikset smartcode lock blinking red keypad
Another cause for the red LED blinking on your Kwikset lock, especially when it beeps 3 times is it could be jammed or misaligned. When this happens, check and see if the door is securely latched or aligned properly. If needed, you can also adjust the strike plate to get the latch moving freely again.
You can read more here: https://revolar.com/why-is-my-kwikset-lock-blinking-red/
Need to reverse bolt
Called "handing" the lock (left-hand or right hand door hinges):Remove the battery pack. Keep the door open.Hold down the "Lock" button on the exterior keypad and at the same time, insert the battery pack into the interior assembly. Keep holding down the lock button until you hear two beeps, which will take approximately 30 seconds. During that time, the Smartcode mechanism will automatically drive in and out several times to determine proper handing.Done!There is an excellent installation & programming video where you can watch how to do this, and it also explains the features of the internal slide switches.http://www.kwikset.com/Videos/Vitro/smartcode.aspxGood luck!
Keypad doesn't light up.
If this is a battery operated lock then the backlight doesn't stay on (otherwise it will wear the batteries out). To make the keys light up when you want to enter your code you have to push the lock button on the keypad first. If the keypad light has never come on then open the door and manually lock the interior lock then press the keypad lock button then the above instructions will work. This is the solution I got from Kwikset customer support and it worked for me. Hope this helps you.
I want to remove the old cod
This model lock will hold 2 codes, so apparently all you've dons so far is add a second code. Try reprogramming it again, using your newer code again so it will overwrite the older one. In other words, you will have two codes entered, both will be the same.If this doesn't work for you, contact Kwikset Customer Service from this link:http://www.kwikset.com/Customer-Support/Contact-Us.aspx
