20 Most Recent Schlage BE365-CAM BE365CAM505 Lifetime Polished Brass Electronic Security K Questions & Answers
2answers
Cannot remove an old schlage door knob
It is a small allen key (hex head) that comes with the lockset when purchased. They are just threaded into the handle (knob) and sets into a reset when threaded in. You can take some putty and push it into the hole and gently remove to make a negative imprint of the allen key, go to a local home center like Lowes or H. Depot and match it up. You can buy a set of allen keys that are like a pocket knife with multiple allen keys. Note, it is very thin. An alternative is to purchase another similar Schlage lockset, open carefully, use the key, and return the lockset saying it is the wrong one. Not nice to do, but in this economy every penny counts. I hope this helps and good luck.
11/8/2014 8:13:41 AM • Schlage... • Answered on Nov 08, 2014
0answers
Change code
Be the first to answer 1/16/2014 3:18:06 AM • Schlage... • Posted on Jan 16, 2014Be the first to answer
0answers
I need to change combination
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.Complete installation & programming instructions can be found here:http://consumer.schlage.com/Project%20Documents/P515-858.pdfNotice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/Videos for installing and programming can be found on this page:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxScroll down and find them under the heading Electronic Security--Keypad deadbolt 365Good luck--and please provide feedback if this helps!
11/9/2011 4:44:31 PM • Schlage... • Answered on Nov 09, 2011
Hi does this lock auto lock like the one with a
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.To enable/disable this feature, enter your Programming Code--press the Schlage butt0n--Press 7.Each time you do this, you toggle between enabled and disabled."How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.Complete installation & programming instructions can be found here:http://consumer.schlage.com/Project%20Documents/P515-858.pdfNotice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/
11/9/2011 2:13:07 AM • Schlage... • Answered on Nov 09, 2011
How to reset the code? How many codes we can
11/8/2011 6:59:22 PM • Schlage... • Answered on Nov 08, 2011
I know I have set up the code to work and I can
11/8/2011 6:53:47 PM • Schlage... • Answered on Nov 08, 2011
How do you enter a code to lack/unlock the
11/8/2011 6:22:14 PM • Schlage... • Answered on Nov 08, 2011
Keyless lock is coded properly,
This link will take you to the page that you need to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Deadbolt 365There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/8/2011 4:54:20 PM • Schlage... • Answered on Nov 08, 2011
Put a new battery in it peeps and thats it no
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.This number is the programming code referenced in the information for changing the entry code.This link will take you to the page that you need to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Deadbolt 365There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/6/2011 10:34:32 PM • Schlage... • Answered on Nov 06, 2011
How do I reset the
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker (more about that below).
"How can I program my electronic keypad lock when the instructions with the programming code have been lost?"
9/17/2011 2:51:41 PM • Schlage... • Answered on Sep 17, 2011
How do erase a code and add a new one?
8/26/2011 12:16:06 AM • Schlage... • Answered on Aug 26, 2011
I just moved into a
The sticker you are looking for should be found on the back of the keypad side, not the battery and manual turnlock side. Without this number, you cannot reprogram the lock:
8/20/2011 2:49:13 PM • Schlage... • Answered on Aug 20, 2011
Lost the instructions How do I reset the entry
8/20/2011 2:42:32 PM • Schlage... • Answered on Aug 20, 2011
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
8/12/2011 3:06:58 PM • Schlage... • Answered on Aug 12, 2011
I need the reset codes
The reset code is on the inside of the inside panel on a sticker.
8/11/2011 7:18:32 AM • Schlage... • Answered on Aug 11, 2011
Schlage BE365-CAM  BE365CAM505 Lifetime Polished Brass Electronic Security K Logo
43 questions posted
Top Schlage Locks & Locksmithing Experts
john h
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Schlage Locks & Locksmithing
Most Popular Question
erase old code input new code
  • Locks & Locksmithing
