20 Most Recent
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Questions & Answers
Door has worked fine for
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Keypad does not take code.
This link will take you to the page you need, to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Entry Flex-Lock...There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
How do ypu set the
This link will take you to the page you need, to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security--Flexlock...There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
I tap the code in i hear the little noise it makes
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.This number is the programming code referenced in the information for changing the entry code.This link will take you to the page that you need to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Entry Flex-lock FE595/Keypad Entry Auto-Lock FE575 DocumentsThere's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (third item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
My Cobra MPC by schlage
I don't have a direct answer, but here is the contact info you need for customer service:Schlage Lock CompanyCustomer Service Department2119 E Kansas City RdOlathe, KS 66061United States Customer SupportWarranty & Technical Information: 1.888.805.9837http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspxSchlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Keypad indicates green but does not unlock door.
I don't have a direct answer, but here is the contact info you need for customer service:Schlage Lock CompanyCustomer Service Department2119 E Kansas City RdOlathe, KS 66061United States Customer SupportWarranty & Technical Information: 1.888.805.9837http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspxSchlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Lost instructions need to change keypad number
You will find the information that you need beginning on this web page:
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
Lost instruction book. Need to know how to chance
I'm directing you to this page, where you will be able to scroll down and find the information for your lock FE 595. Here you should find everything you need to know. Good luck!
Just cut and paste the link into your browser or type it in directly in the search bar.
Schlage camelot key pad does
Here is a link to the installation instructions:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Olathe, KS 66061
How to set code?
Here's a link to a video on how to program your lock:
Do I have to reprogram
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery?
The Schlage Keypad Lock and Keypad Deadbolt does not need to be
reprogrammed after replacing the battery. All settings are retained in
the memory of the lock, including valid user codes and the programming
code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
My backlit led doesn't come on even when I hit the
Olathe, KS 66061
1.888.805.9837
Change code
This link will give you instructions for various models of Schlage locks:
There is a video for changing codes on this page!
How do i reprogram it
There is a video on that page!
