SOURCE: how to reset time
Diplodocs - CASIO: 1506 references - Your user manual immediately available! Your CASIO has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of Casio Edifice, the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch. Feel free to ask question regarding your to watch so i can assist..
Hope this may help;
Regards,
VOTIT
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
SOURCE: setting the analog dials on the casio edifice EFA 120
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Go here to get the instruction manual
SOURCE: casio edifice mens watch user instructions needed
Go in alarm mode by pressing the mode button once twice...depending on the modes you have and then press one of the remaining buttons, usually top right button on most edifices. this toggles between alarm on and off. this shall do....
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
Please dont forget to vote this answer was helpful.
Many thanks
