Dryers Logo
Melissa Sheppard Posted on Apr 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you fix a H2 on dyson hot/cold fan - Dyson Dryers
NOEL
Level 3:
Top Expert:
  • Dyson Master 8,606 Answers
  • Posted on Apr 26, 2019
NOEL
Dyson Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322393
Points
68630
1 Related Answer
deremiadeyi
Joseph Aderemi
  • 98 Answers
  • Posted on Oct 28, 2018
SOURCE: H2 error code on Dyson hot/cold fan unit.
what is the question?
My dyson hot and cold fan is displaying code C2 and won't turn on or off
quote from amazon site***Mine also showed H2. I had a suspicion that it was the remote causing it. Changed the remote battery (CR 2032), turned on the heater and let it circulate for 3 minutes, then I went and tested all remote buttons. It worked! No more H2 error code!
Amazon Customer · September 11, 2018
1helpful
Hi. I have a Dyson AM05 fan heater purchased July 2014. Whilst the cold air works brilliantly the hot air doesn't work at all. It shows an error message E8. Any advice?
I suspect that the microprocessor detected an overheat fault and is keeping it in E8 mode to prevent fire. The code needs to be cleared somehow. If it has some buttons on the front then try holding one whilst plugging it in. This may reset it. The reset will be something along those lines. Don't open it because if you can't fix it that way you need to take it back to the shop.
Dyson hot and cold
Hi there, it's Jack at Dyson.
It sounds like your heater is shutting off because the ambient temperature is higher than or equal to the target temperature you've chosen (shown on the LED display on the front of the machine):
The heater's intelligent thermostat is engineered to turn the machine on only when needed when the ambient room temperature drops below the target temperature. However, we're happy to help you make sure your heater is working as intended. Please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson hot and cold fan wont turn on
Inside the electric field there is an insulations tape inside the coil in a most white or black colored tape where these temperature fuse is broken or also fuse in the powercable
Dyson hot and cold fan only works in hot mode
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Top Dyson Dryers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
