Please provide the model number of your device, and what if anything you tried, do you have access to the the settings? In short reguardless of what platform you use (I.E apple rim android etc) this process is generally almost the same,
Try to navigate to your settings and find to email or accounts withing your settings- under the setting in sub menus look for "add account" or "add email", if you do not see this anywhere in any setting sub menu then go to next try
Try to navigate to email and in sub menu or setting attempt to locate "add account" or "add email" if you do not see this in any sub menu see below
Try mail icon, then click options, click email account management, select
[email protected], a menu pops up, select delete account, start over and use same method to add
[email protected] to the device
Ok so this means you did not find it in such event if you provide me with a model number I can give you a step by step guide, I attempted to show you how to add an account as for some platforms do not allow you to change the primary email address of the device without a hard reset of the device, only to add addresses but you can add accounts and disable receiving mail from that account,even change the password to stop the device from getting emails, but give me your model number and I may better assist you--Good Luck.
