Refrigerators Logo
Alex Briones Posted on Apr 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting up ADC-V620PT - Refrigerators
Darrin P. De May
Level 3:
Master:
  • Master 665 Answers
  • Posted on Apr 23, 2019
Darrin P. De May
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
153453
Points
1951
Read the Manual:
https://www.linkinteractive.com/pdfs/user-guides/v620pt.pdf&ved=2ahUKEwjV9dDRgufhAhXTJTQIHX5qD6wQFjAAegQIARAB&usg=AOvVaw0ge7K9G_wMp0Iq3zh75ifW
How do you access the ADC using microopython on a raspberry pi pico? the only answer seens to be the_adc_value- = machine.ADC 26 .read_u16
To access the ADC (Analog-to-Digital Converter) using MicroPython on a Raspberry Pi Pico, you can follow these steps:
  1. Import the necessary modules: Begin by importing the required modules for using the ADC in MicroPython. In this case, you'll need the machine module.
pythonCopy code
import machine
  1. Create an ADC object: Next, create an instance of the ADC object using the desired pin number.
pythonCopy code
adc = machine.ADC(26) In the example above, pin 26 is used as an example. You can replace it with the specific pin number to which your analog sensor is connected.
  1. Read the ADC value: To read the analog value from the ADC, you can use the read_u16() method.
pythonCopy code
adc_value = adc.read_u16() The read_u16() method returns the raw analog value as a 16-bit unsigned integer.
You can then use the adc_value variable to perform further calculations or use it as needed in your code.
It's important to note that the specific pin number and configuration may vary depending on your setup and the ADC pin you are using on the Raspberry Pi Pico. Refer to the documentation or specifications of your specific ADC module for the correct pin assignment and any additional configuration required.
Additionally, make sure you have the appropriate MicroPython firmware installed on your Raspberry Pi Pico, as it should include the necessary ADC support.
I have a M8149 Cinema dispaly 22" and want to connect to late 2009 Mac mini. The monitor came with a strange adaptor set of ADC input to 1x each of usb, 24Pin 92x rows of 8) male ADC, and another plug...
The Apple 22" Cinema display M8149 (ADC) is one that is not compatible.
It might be better to find another brand display to work with your 2009 Mac Mini. The Apple model A1081 is DVI, but for the age (its 8 years old, the lamps are likely dimmer than new...) I would look for a resolution-compatible DVI input display (Dell Ultrasharp, etc..).
1helpful
Tt18hpxlt defrost timer
there is no defrost timer in this model,it is called an A.D.C. adaptive defrost control and is located in the refrige compartment just above and behind the cold control setting inside this plastic case,remove this case from the top of the refrigerator compartment and you will see a small printed circuit board,this is the A.D.C.
1helpful
3helpful
2answers
Samsung clp610nd ADC Power Slope
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
ADC for ECG signal
example of design circuit using OTA to detect EMG/ECG signals.
Feb 27, 2009 • ADC Medical
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
