This is a GE Advantium convection/mircowave oven PSB9120SF1ss
SOURCE: Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the mount is broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Makes loud noise and doesnt heat.
Most likely the magnetron is bad. I'm guessing a household model. Unplug unit and unplug the connection at the magnetron and run again. The noise will likely be gone. If you do replace the magnetron, replace the diode that goes with it.
SOURCE: Everything works (clock, timer, inside
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
heatman101
