Nothing comes up on display. I used the DC out plugged into camera I removed battery and memory cards and it still will not boot up.
SOURCE: WHY IS MY CAMERA NOT STAYING ON ?
It sounds like the memory card slot has been damaged in some way. This probably means a new circuit. I would suggest you find a Kodak service centre in your area. Hopefully the camera is still under warranty.
SOURCE: digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
SOURCE: Sony DSC-W120 Digital camera Problem: The
When i switch on the power button to take photo "E:91:01" code and flash symbol blinks on screen and flash
does not work also.
plz let me knw solution for this waiting for reply.
M talking about my sony cybershot digital camera model no DSC-W120
SOURCE: HP 6310: memory card light flashing, printer will not turn on.
Sounds like a good fix, how does one go about reseting the firmware?
SOURCE: I need help with what sort of memory card I should be using
That camera doesn't support the HC memory. Just get a regular SD memory card.
